How to open RITM and SCTASK when running Open a Catalog Item (SP) via ATF
Gian1
I am trying to run an ATF scenario where Open a Catalog Item (SP) and have a Order a Catalog Item (SP) as submit.
When we open an existing record, it fails to open SC_TASK
Any ideas?
9 REPLIES 9
Hi Ankur,
This is my step 4: Open an Existing Record
And I get the error message
FAILURE: Failed to open the 'sc_task' form with id '6ce8238adb628950e41fc773059619a0'
Table 'sc_task' does not have a record with id '6ce8238adb628950e41fc773059619a0'
You need to open existing record by giving condition as RITM sysId
can you share your steps
Hi Ankur,
There is no section to add any conditions as you can see below;
you want to open catalog task or RITM form?
Gunturi Haribab
In the same scenario, I have to open both the SCtasks simultaneously and I have to close them. How to do that in the ATF?
