how to parse json string and display it in ui page
suprakash
Giga Expert
I need to display the first five created asset names and asset category according to their creation date in a Ui page in table format . i have written script include
--script include ---
var getAssetClass = Class.create();
getAssetClass.prototype = Object.extendsObject(AbstractAjaxProcessor, {
  getAsset: function() {
  var gr = new GlideRecord('alm_asset');
  gr.orderBy('sys_created_on');
  gr.setLimit(5);
  var assets=[];
  while(gr.next()){
      asset={};
      var asset_name = gr.getDisplayValue('display_name');
      asset.name=asset_name;
      asset.category=gr.getDisplayValue('model_category');
      assets.push(asset);
      //gs.print(asset.name+"!!!!!!!!!!"+asset.category);
  //gs.print(assets);
  var assetsString = JSON.stringify(assets);
        return assetsString;
  //getDisplay: function() {
  // return 10;
      type: "getAssetClass"
-- client script for testing---------
var ga = new GlideAjax('getAssetClass');
  ga.addParam('sysparm_name','getAsset');
  //ga.addParam('sysparm_name1','getDisplay');
  //ga.addParam('sysparm_user_name',"Bob");
  ga.getXML(HelloFun);
  function HelloFun(response) {
  //console.log(answer);
  alert(answer);
i am not able to parse the JSON string and display it in ui page in table format using HTML
hvrdhn88
Giga Patron
Hi Suprakash,
In UI Page you need to mention your code under "g:evaluate" tag then store it in a variable and call it in client script.
Please find the below example   : It's the OOTB ui page " approval_engines ".
Please check the below code.
HTML Script
<g:ui_form>
    <g:evaluate var="jvar_engines">
          function getWorkflowManagedTables() {
                  // sys_ids of the approval activities (wf_activity_definition)
                  var approvalActivities = getApprovalActivityDefinitionIds();
                  var arrayUtil = new ArrayUtil();
                  var workflowTables = [];
                  var grV = new GlideRecord('wf_workflow_version');
                  grV.addQuery('published', true);
                  grV.query();
                  while (grV.next()) {
                          if (arrayUtil.contains(workflowTables, grV.table + ''))
                                  continue;
                          grA = new GlideRecord('wf_activity');
                          grA.addQuery('workflow_version', grV.getUniqueValue());
                          grA.addQuery('activity_definition', 'IN', approvalActivities);
                          grA.query();
                          if (grA.next())
                                  workflowTables.push(grV.table + '');
                  return workflowTables;
                  function getApprovalActivityDefinitionIds() {
                          var approvalActivityIds = '';
                          var gr = new GlideRecord('wf_activity_definition');
                          gr.addQuery('attributes', 'CONTAINS', 'approval');
                          while (gr.next()) {
                                  var att = GlideStringUtil.decodeAttributes(gr.attributes + '');
                                  if (att.get('approval') + '' == 'true') {
                                          if (approvalActivityIds.length > 0)
                                                  approvalActivityIds += ',';
                                          approvalActivityIds += gr.sys_id + '';
                          return approvalActivityIds;
          var workflowTables = getWorkflowManagedTables();
          var tables = new GlideDBObjectManager.get().getAllExtensions('task');
          var tableList = [];
          for (var i = 0; i != tables.size(); i++) {
                tableList.push(tables.get(i) + '');
          tableList.sort();
          var engines = [];
          for (var i = 0; i != tableList.length; i++) {
                var engine = {};
                engine.table = tableList[i];
                var td = new GlideTableDescriptor.get(engine.table);
                engine.label = td.getLabel() + '';
                engine.approval = new ApprovalEngineUtils().getEngineForTable(engine.table);
                var notesKey = "approval_engine.notes." + engine.table;
                var notes = gs.getMessage(notesKey) + '';
                if (notes == notesKey)
                      notes = '';
                engine.notes = notes;
                if (new ArrayUtil().contains(workflowTables, engine.table)) {
                      var additionalNotes = gs.getMessage('Workflows are managing approvals on this table.') ;
                      if (engine.approval == 'off')
                            engine.disable = true;
                      else
                            additionalNotes += ' ' + gs.getMessage('This should be set to "Turn Engines Off".');
                      if (engine.notes == '')
                              engine.notes = additionalNotes;
                engines.push(engine);
          var json = new JSON();
          json.encode(engines);
    </g:evaluate>
    <table border="0" cellspacing="0" cellpadding="0">
          <tr>
                <g:no_escape>
                      <td colspan="5">${gs.getMessage("approval_engine.description")}</td>
                </g:no_escape>
          </tr>
    </table>
    <table border="0" cellspacing="2" cellpadding="0" id="engines">
          <tr class="header">
                <td nowrap="true" class="column_head" align="center">${gs.getMessage("Table")}</td>
                <td nowrap="true" class="column_head" align="center">${gs.getMessage("Name")}</td>
                <td nowrap="true" class="column_head" align="center">${gs.getMessage("Approval Engine")}</td>
                <td class="column_head" align="center">
                      ${gs.getMessage("Notes")}
        <input id="make_spacing_ok" style="visibility:hidden;width:0px;" title=""/>
                </td>
          </tr>
    </table>
    <input type="hidden" id="tables" name="tables" />
    <script>
          var g_engines = ${jvar_engines};
    </script>
    <g:dialog_button onclick="save()" style="" id="engine_save" type="submit">${gs.getMessage("Save")}</g:dialog_button>
</g:ui_form>
Client script
var t = gel("engines");
var tbody = t.firstChild;
initEngines();
function initEngines() {
    var tables = [];
    for (var i = 0; i < g_engines.length; i++) {
          buildEngineTR(g_engines[i], i);
          tables.push(g_engines[i].table);
    var e = gel("tables");
    e.value = tables.join(",");
function buildEngineTR(engine, i) {
    var tr = cel("tr", tbody);
    if ((i % 2) == 0)
          tr.className = "even";
    else
          tr.className = "odd";
    var hasEngine = false;
    if (engine.approval)
          hasEngine = true;
    var td = cel("td", tr);
    td.className = "vt";
    td.style.whiteSpace = "nowrap";
    if (hasEngine)
          td.innerHTML = "<b>" + engine.label + "</b>";
    else
          td.innerHTML = engine.label;
    td = cel("td", tr);
    if (hasEngine)
          td.innerHTML = "<b>" + engine.table + "</b>";
    else
          td.innerHTML = engine.table;
    td = cel("td", tr);
    buildEngineSelect(td, engine);
    td = cel("td", tr);
    td.innerHTML = engine.notes;
function buildEngineSelect(td, engine) {
    var select = cel("select", td);
    select.className = "vt";
    select.id = "engine_" + engine.table;
    select.name = select.id;
    select.title = "Approval Engine";
    if (engine.disable)
          select.disabled = "disabled";
    addOption(select, "approval_engine", "Approval Rules", engine.approval == "approval_engine");
    addOption(select, "process_guide", "Process Guides", engine.approval == "process_guide");
    addOption(select, "off", "Turn engines off", engine.approval == "off");
function save() {
Hope it will help you.Let me know if you need any further information.
Harshvardhan
PS: Hit like, Helpful or Correct depending on the impact of the response.
Shamma Negi
Hi Suprakash,
See the below code:
HTML :
<g2:evaluate var="jvar_gr2" object="true">
var crrSysID = "${RP.getWindowProperties().get('sysparm_crr_sysid')}";
    </g2:evaluate>
<g:ui_form>
  <input type="hidden" value="$[crrSysID]" name="crrSysId" id="crrSysId" />
</g:ui_form>
How to use this in CLIENT SCRIPT :
var crrSysId= $('crrSysID').getValue();
This way you can create variable in HTML and use it in Client script.
Let me know in case of any questions.
Shamma
Regards,Shamma Negi
