How to pass an array of values from Script Include to Catalog Client Script?
User205031
We have a requirement. If a user selects an Application from 'app_service' then tags related to that application will populate in a different field. So, if an application has 3 tags, how to populate those 3 tags? If an application has 1 tag, it is populating fine but problem is with more than 1 tag.
Catalog Client Script:
var a = g_form.getValue('app_service');
alert(a);
var ga = new GlideAjax("TagPop");
ga.addParam("sysparm_name", "getTagName");
ga.addParam("sysparm_groupid", a);
ga.getXML(setTagName);
function setTagName(response) {
g_form.clearValue('subscription_name');
g_form.clearOptions('subscription_name');
alert(answer);
g_form.setValue('subscription_name', answer);
Script Include:
var TagPop = Class.create();
TagPop.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getTagName: function() {
var efg = '';
var nam = this.getParameter('sysparm_groupid');
//gs.log('h1' + nam);
//var t = nam.getDisplayValue();
//gs.log('h2' + t);
var abc = new GlideRecord('label_entry');
abc.addQuery('title', 'CONTAINS', nam);
//var vendors = [];
abc.query();
if (abc.next()) {
efg = abc.label.getDisplayValue();
//vendors.push(efg.getUniqueValue());
return efg;
//return 'sys_idIN'+vendors.toString();
type: 'TagPop'
Please help!
Updated CLient Script code to be used here as below:
    if (newValue) {
        var ga = new GlideAjax('getTags');
        ga.addParam('sysparm_name', 'getTagsValue');
        ga.addParam('sysparm_val', newValue);
        ga.getXML(getTags);
    function getTags(response) {
        alert(answer);
		var splitAnswer = answer.split(',');
		for(var i=0;i<splitAnswer.length;i++){
			g_form.setValue('description',g_form.getValue('description') + '\n' + splitAnswer[i]);
This will ensure that tags appear in different lines as you said, did not read it initially but have modified it. Let me know for an issue here.
Shloke
15 REPLIES 15
Stefan O1
In the catalog client script in Patryk's example use
var answer = JSON.parse(answer);
var tagPop = answer.split(',');
