‎04-03-2018 11:35 PM
I am having a catalog item which is having 3 fields [Name, Location, Contact] which is having its values like [Angshuman , India, E-Mail].
Now I want exact same values with field name to be imported on the Description field on the catalog task. How will this be possible?? If it will be possible using the workflow or we need to create any rule for the same?
Thanks & Regards,
Angshuman
‎04-04-2018 12:26 AM
In the catalog task activity of the workflow write down advanced script like
task.description ="Name is:" +current.variables.Name+".Product is:"+current.variables.Product ;
Use the variable names in place of bold text as per your need
‎04-04-2018 12:03 AM
Yes. If catalog item is different for both the tasks, it will populate the corresponding fields.
‎04-04-2018 12:11 AM
I guess I didn't clear it to you.....
So, the scenario is there is a Catalog named A which has 2 catalog task associated with it 1 & 2....
Now there are fields in Catalog task such as Name Product Location Contact....
I want field name & its values [Name & Product] to be populated in Catalog Task 1 , Description Field.
and in Catalog Task 2 [Location & Contact] field name & values should get populated in the Description Field.
Will the same be achievable using the BR, or we can write some script in the workflow?
‎04-04-2018 12:31 AM
Yes. Better to use it on Catalog Task activity in the workflow while creating the catalog task.
In the advance script
task.description = 'Name: '+current.variables.name+'\nProduct: '+current.variables.product.getDisplayValue();
Similarly for task 2
task.description = 'Location: '+current.variables.location.getDisplayValue()+'\nContact: '+current.variables.contact.getDisplayValue();
