how to populate the catalog variable values to RITM description
Pushpa
Mega Expert
Hi Team,
how to populate the current catalog variable values  to RITM description
below variables and variable set fields.
i have 3 variables and one variable set (variable set have 2 fields).
variables
1. account
2. year
3.quarter
variable set
4. select location  (location and balance)
how write workflow run script
@Ankur Bawiskar
Pushpa
account variable should work fine using this
current.variables.account.getDisplayValue();
OR you can query the account table with the sys_id and print the name
then for stockroom showing country do this
var desc = current.variables.description;
if (current.cat_item.name == "Laptop Projection Request") {
    desc += '\nAccount: ' + current.variables.account.getDisplayValue();
    desc += '\nYear: ' + current.variables.year;
    desc += '\nQuarter: ' + current.variables.quarter;
    var parser = JSON.parse(current.variables.add_stockroom_location_and_projection);
    var arr = [];
    for(var i=0;i<parser.length;i++){
        var gr = new GlideRecord("alm_stockroom"); // give here the table name
        gr.addQuery("sys_id", parser[i].stockroom);
        if (gr.next()) {
            var str = '';
            str = str + "Stockroom: " + gr.location.country + " | " + gr.name + " Projection: " + parser[i].projection;
            arr.push(str);
    desc += '\nAdd Stockroom Location and Projection: ' + arr.join('\n');
    current.description = desc;
    current.update();
25 REPLIES 25
your variable add_stockroom_location_and_projection seems to be MRVS so you need to query everytime to that stockroom table to get the display value
Hi Ankur,
below code working only variable vales getting. but variable set getting undefine.
//desc+='\nCost:'+current.cat_item.price.getDisplayValue()+' per month';
    desc += '\nYear: ' + current.variables.year.getDisplayValue();
    desc += '\nQuarter: ' + current.variables.quarter.getDisplayValue();
    desc += '\nAdd Stockroom Location and Projection: ' + current.variables.add_stockroom_location_and_projection.getDisplayValue();
current.update();
output:
test
Account: project1
Year: 2021
Quarter: Q2
Add Stockroom Location and Projection: undefined
thanks,
Pushpa
Hi Pushpa,
your variable set add_stockroom_location_and_projection is MRVS so it has JSON
So it won't work directly.
I have already shared the working script in my below post. please check that and use that
asifnoor
Try like this.
current.update();
Mark the comment as a correct answer and helpful if this helps.
Hi
below code is working but variable set values not getting
