how to populate the catalog variable values to RITM description
Pushpa
Mega Expert
Hi Team,
how to populate the current catalog variable values  to RITM description
below variables and variable set fields.
i have 3 variables and one variable set (variable set have 2 fields).
variables
1. account
2. year
3.quarter
variable set
4. select location  (location and balance)
how write workflow run script
@Ankur Bawiskar
Pushpa
account variable should work fine using this
current.variables.account.getDisplayValue();
OR you can query the account table with the sys_id and print the name
then for stockroom showing country do this
var desc = current.variables.description;
if (current.cat_item.name == "Laptop Projection Request") {
    desc += '\nAccount: ' + current.variables.account.getDisplayValue();
    desc += '\nYear: ' + current.variables.year;
    desc += '\nQuarter: ' + current.variables.quarter;
    var parser = JSON.parse(current.variables.add_stockroom_location_and_projection);
    var arr = [];
    for(var i=0;i<parser.length;i++){
        var gr = new GlideRecord("alm_stockroom"); // give here the table name
        gr.addQuery("sys_id", parser[i].stockroom);
        if (gr.next()) {
            var str = '';
            str = str + "Stockroom: " + gr.location.country + " | " + gr.name + " Projection: " + parser[i].projection;
            arr.push(str);
    desc += '\nAdd Stockroom Location and Projection: ' + arr.join('\n');
    current.description = desc;
    current.update();
25 REPLIES 25
Ankur Bawiskar
Hi Pushpa,
update your script as this
	desc += '\nAccount: ' + current.variables.account.getDispayValue();
	var arr = [];
		var gr = new GlideRecord("stockroom table"); // give here the table name
		if (gr.next()) {
			var str = '';
			str = str + "Stockroom: " + gr.getDisplayValue() + " Projection: " + parser[i].projection;
			arr.push(str);
	current.update();
Hi Ankur,
Thanks for your reply
now account getting undefined.
and same update it into Task (now only populate catalog description value into task description) how to get all ritm description into task
Pushpa
account variable line of code was not touched.
you are still using getDisplayValue() on the account variable
	var arr = [];
		if (gr.next()) {
			var str = '';
			arr.push(str);
	current.update();
is the stockroom related information coming fine?
