how to populate Yes or No alert?
Rithvik2
I had a select box with options as yes or no or none[none is not a default one...its also a option]options..
when the user selected as "yes" then we need an alert popup with "Would you like to continue?" or "Not" options
If user selected No then we need to change the select box option to None else selected option i.e., Yes will be as it is..there will be no change
Ankur Bawiskar
You can have onChange Client Script on that Select box variable
But you cannot have custom text on the confirm box. It would be OK and CANCEL
// use valid choice value here
if(newValue == 'yes'){
if(!confirm('Would you like to continue?')){
// user clicked on CANCEL
g_form.clearValue('variableName'); // give your variable name here
Hi @Ankur Bawiskar
If I have multiple Yes or no variables. on the selection of yes for the two questions. I want to show an alert. how to achieve that?
Hi Sai,
onchange client script
Hi Ankur,
can you please share a Snippet?
Hi Sai,
you will require multiple onchange client script on each variable
