how to provide validation for input URL field , either using string field or URL type field
Abhradipa Baner
I had added an URL field in form where users will give URL values as input ; and I want to validate that URL field that means if user enters URL consisting (https / www) it will take the value OR ELSE if user enters string or integer value in place of URL field ,it will show alert message to the USER.
How can I fix this?
Please help.
Ankur Bawiskar
you can use onChange client script + Regex for this
OR
you can also use onSubmit client script + Regex
Example onSubmit script
function onSubmit() {
	var url = g_form.getValue('url_field');
	var validateURL = /https?:\/\/(www\.)?[-a-zA-Z0-9@:%._\+~#=]{2,256}\.[a-z]{2,6}\b([-a-zA-Z0-9@:%_\+.~#?&//=]*)/.test(url);
	if (!validateURL) {
		g_form.addErrorMessage(getMessage("Enter a valid URL"));
		return false;
Matt102
Giga Guru
Add an onChange Client script to the field.
https://docs.servicenow.com/bundle/sandiego-application-development/page/script/client-scripts/concept/client-scripts.html
In that script use a regex to match what you will allow and display a message if format incorrect.
script _could_ be something like:
var re = <Your regex>;
if (!re.test(newValue)) {
  alert("invalid url");
    return false;
hth,matt
Hi again,
I always think its work looking at anything that ships  OOB.
I was just looking around client scripts and found on for the ldap_server_url table, it's called 'Validate Server URL for XSS' - not sure if you'll have that table. If not script is:
	if (newValue.indexOf(">") > -1 || newValue.indexOf("<") > -1) {
		var msg = getMessage("Characters < and > are not allowed");
		g_form.showFieldMsg(control, msg, "error");
		g_form.hideFieldMsg(control);
Ankur Bawiskar
OR
	if (!validateURL) {
		return false;
Hi Ankur,
This is working. Thanks for the suggestion.
Abhradipa
