How to put reference qualifier in <g:ui_reference tag in UI macro?
I have a used one ui macro in a catalogue item. For one reference field i have used <g:ui_reference tag, how to put reference qualifer in <g tag?
Sirraj
I have solved this issue by referring below thread,
https://community.servicenow.com/community?id=community_question&sys_id=78da0b6ddb5cdbc01dcaf3231f961998
- Sirraj
14 REPLIES 14
Hi Sirraj,
Yes that's the main point here
passing values from <script> tag to the server side tag i.e. g:ui_reference of g:evaluate
Hi Ankur,
Can you help me with some sample code.
Sirraj
Hi Sirraj,
That is not possible i.e. sending values from <script> tag into g:evaluate or g:ui_reference
what I would suggest is to have normal variables only
i.e. 1st variable string or drop down as per your choice
2nd variable a reference variable where you can apply the reference qualifier.
why you want to use UI macro and g:ui_reference tag? any specific reason
Yes Ankur, Its a kind of table. For that i was advised to use ui macro. my catalog forms look like this.
So var 1 is a normal variable and var 2 is used in macro.
Hi Sirraj,
The second variable seems to be catalog table variable?
check below link:
https://community.servicenow.com/community?id=community_question&sys_id=db02c7e9db98dbc01dcaf3231f96...
