How to reference knowledge article from a service catalog
12-15-2015 07:13 AM
I am trying to attach/reference a KB article from a service catalog. I'm a new administrator, so I'm not really sure what the plausible ways to accomplish this are. Some ideas I have are:
- Include an href link in the description - this could get missed
- have a workflow email the user after the item is ordered - not sure how to accomplish this...
- attach (or reference) the KB article from the service catalog item - I was under the impression attachments were just files, so I'm not sure if this is a viable option.
Thanks for your help everyone!
This may be very similar to Insert knowledge article to the work notes of a catalog task , and if so I apologize for the double posting.
Service Catalog
12-15-2015 11:03 AM
I retract my previous comment. It is the first. Mind helping me with that workflow b-rad? I have a notification added, but how do I put the opened_by.email in the email field so it dynamically inserts the email address? It just gave me red when I tried.
12-15-2015 11:12 AM
12-15-2015 11:15 AM
Hi WIlliam,
Try using the tree picker on the right side (third icon from the top in your screenshot) to go through and select the Opened by field.
12-15-2015 11:19 AM
Ok, I will keep working with that tree picker. Am I in the right field?
12-15-2015 11:23 AM
That did it, thank you! I was in the variable selector, not the tree picker!
