How to remove the incidents associated with problem records
Vamshi Krishna2
Hi, i have a problem record where the incidents got attached to it  I want to remove the incidents for the problem record from the related list but I could not find the edit option to remove the incidents
2 ACCEPTED SOLUTIONS
AndersBGS
Hi @Vamshi Krishna2 ,
Ok, then please right click the header in the incidents related list:
and choose "list control".
Afterwards remove the check mark in "omit edit button" and press update
Afterwards you will have the possibility to edit in the related list:
f my answer helped for a resolution to your question, please mark my answer as accepted solution and give a thumb up.
Best Regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
AndersBGS
By the way @Vamshi Krishna2 ,
If you want to add the remove incident to the drop down list, you just need to add an UI action with following settings:
Then you can chose by yourself, if you would like the option by UI button or UI action in the drop down list.
Best Regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
9 REPLIES 9
Choose delete instead, it will not delete the record, but instead just remove it form the problem record related incident list.
Best Regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
It will delete the records I have tested it in the dev
AndersBGS
Best Regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
AndersBGS
Best Regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
Thank you so much Anders this worked.
