‎05-10-2021 02:52 AM
How to send email notification for every 24hrs, until 5days from the creation date.
The first notification should be fired, after 24hrs the record got created. From then, the email should be sent for every 24hrs up to 5days.
‎05-11-2021 12:01 AM
gr.sys_created_by will give user name and not sys_id or email address
event parm1 requires either user sys_id or user email address
So I mentioned which field on termination task is referring to sys_user? use that field there
So that the event gets the user sys_id
OR if you are having any field on termination task which stores user email then use that there
‎11-08-2023 12:19 AM
Where do i need to write above script either in Business rule or in scheduled job ?
‎09-09-2021 09:39 AM
Hi Ankur,
I have a similar requirement but it should skip the weekends.
If the ticket is raised today (09-09-2021 21.20.35 "Thursday") after 24 hours means, it should trigger on "10-09-2021 21.20.35 Friday" 48hours from created means, it should trigger on "13-09-2021 21.20.35 Monday" It should skip Saturday and sunday
What changes should be done to the script
regards,
Appu
‎11-09-2023 11:20 PM
@Ankur Bawiskar
Can i get sample flow designer to trigger approval email notification for every 24 hours until 5 days ?
