How to set approval for users with specific role in workflow - Approval user activity script ?
Ridhima4
I want the users with specific role to approve a request, My workflow is working fine but the Approval user script is not working, Please help me with the same. Below is my script mentioned:
var answer = [];
var userRole = new GlideRecord('sys_user_has_role');
userRole.addQuery('role', 'x_adsr_recruit.hiring_manager');
userRole.query();
while(userRole.next()){
answer.push(userRole.user.sys_id);
Ankur Bawiskar
updated script should work fine now
please use this
see the changes in bold
1) use role.name to query with role name
2) use toString() while pushing user to answer array
var answer = [];
userRole.addQuery('role.name', 'x_adsr_recruit.hiring_manager');
userRole.query();
answer.push(userRole.user.toString());
9 REPLIES 9
Hello Ridhima,
I noticed that you have marked my comment as correct earlier, but now it is not. I have also provided a rejoinder with the corrected line of code.
Posting it here again for your reference.
var answer = [];
userRole.query();
  answer.push(userRole.getValue("user"));
Kindly check and mark it correct so that the question is moved to the solved list.
Ankur Bawiskar
please use this
var answer = [];
userRole.query();
Ankur Bawiskar
Just to inform the answer you marked correct will only push 1 user to the answer array
you need to use toString() to get all the users pushed into that array.
OR
use answer.push(userRole.getValue('user'));
I have shared the complete script with both the changes.
Please mark appropriate response as correct & helpful.
Ankur Bawiskar
@Ridhima
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
Mark Roethof
Hi there,
Did my answer help to resolve your question? Or do you still need some assistance on this? Let me know.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
