How to set field(catalog variable) value on requested item using client script
We have one catalog variable type (select box). available choices are yes/no
default value is empty.
we are trying for particular condition , field value should be set to "No" and read only on requested item label.
so we are using on load client script but g_form.setValue('field_name',''); is not working.
How to achieve this.
@Ankur Bawiskar
Thanks in advance,
Sayan Ghosh
12 REPLIES 12
If based on a variable then you need to use below Script :
then use as if (g_form.getValue('variables.VariableName') == ''). Have modified and shared below for reference:
function onLoad() {
    if (g_form.getValue('variables.VariableName') == '') { // Replace your Field Name here
        g_form.setValue('variables.VariableName', 'no'); // Replace Variable Name here and also the correct value of "no" which you can get from your Select Box Variable choice backend value
		g_form.setReadOnly('variables.VariableName',true); // Replace your Varibale Name here/
Else if you want to check based on a Field in RITM form then use the script which was shared before.
Shloke
Shloke
code is not working. let me tell you scenario.
currently variable type is yes/no and default value is no. selected include none option also.
so for particular condition that variable value has to be blank or none on requested item and needs to be mandatory so that user can fill that value .
overall story is we need to change the value from "no" to blank or none and need to make mandatory on requested item based on condition.
we have onchange ui policy.
set value or clear value command isn't working.
hope you get my point.
The statement which you have mentioned now is completely different to what you have mentioned in your Question above.
Write a On Load catalog client script on your catalog item and make sure that the script gets applied on Requested Item view only as shown below:
Now based on the last statement scenario, I have updated the script. Please use this and check:
function onLoad() {
    g_form.clearValue('yes_no_variable'); // Replace your variable name here
    if (g_form.getValue('yes_no_variable') == '') { // Replace your variable name here
        g_form.setMandatory('yes_no_variable', true); // Replace your variable name here
This works for me in my PDI. Let me know if you are facing an issue.
Shloke
Shloke
Hi ,
we are using client script on requested item table. not using catalog client script.
so the option you mentioned not available on that
You can easily handle it via Catalog Client script as I mentioned above.
But you do have an option to do it with Client Script as well. Please use below script in your On load Client Script :
function onLoad() {
    g_form.clearValue('variables.VariableName'); // Replace your variable name here
    if (g_form.getValue('variables.VariableName') == '') { // Replace your variable name here
        g_form.setMandatory('variables.VariableName', true); // Replace your variable name here
Shloke
Shloke
