How to set multiple variable values in a single variable using Run Script(workflow)
Anusha25
After creating Request, few variables like,
variable 1 : A
                  B
                  C
                  D
variable 2: A1
                  B1
                  C1
variable 3:A2
                 B2
                 C2 etc
In Variable 4(multiple line text)the above 3 variable values should populate  with semicolon and space for each value.
29 REPLIES 29
Hi Anusha,
Just tried in my PDI as you expected.
Logic:
var c, d;
c = current.variables.details1.toString().split("\n"); //map your variable names
d = current.variables.details2.toString().split("\n");
for (var i = 0; i < c.length; i++) {
    current.variables.details3 = current.variables.details3 + c[i] + ";";
for (var j = 0; j < d.length; j++) {
    if (d.length == j + 1) {
        current.variables.details3 = current.variables.details3 + d[j] ;// to ignore semicolon for the last word
        current.variables.details3 = current.variables.details3 + d[j]+ ";";
Hope it helps
Murthy
Murthy
Hi Murthy, It was worked for 2 variables , but in my scenario there are 7 variables
but those variables based on condition will populate ,how can i set those variable values in one variable.
below is the attachment that may use
var a, b, c, d, e, f, g;
a = current.variables.active_directory_groups.getDisplayValue().toString().split("\n");
b = current.variables.active_directory_groups_sit_env.getDisplayValue().toString().split("\n");
c = current.variables.active_directory_groups_dev_env.getDisplayValue().toString().split("\n");
d = current.variables.modify_active_directory_groups.getDisplayValue().toString().split("\n");
e = current.variables.active_directory_groups_UAT.getDisplayValue().toString().split("\n");
f = current.variables.active_directory_groups_newordelete.getDisplayValue().toString().split("\n");
g = current.variables.modify_active_directory_groups_dailydropdown.getDisplayValue().toString().split("\n");
for (var i = 0; i < a.length; i++) {
current.variables.ad_groups = current.variables.ad_groups + a[i] + ";" + " ";
for (var j = 0; j < c.length; j++) {
if (c.length == j + 1) {
current.variables.ad_groups = current.variables.ad_groups + c[j];
Instead of splitting it, you can just try to replace '\n' with other character( semicolumn in your case) , it will make easy for you.
Please find updated code below, if you want you can semicolumn while concatenating a,b,c variables at the end.
a = current.variables.active_directory_groups.getDisplayValue().toString().replace("\n",";");
b = current.variables.active_directory_groups_sit_env.getDisplayValue().toString().replace("\n",";");
c = current.variables.active_directory_groups_dev_env.getDisplayValue().toString().replace("\n",";");
d = current.variables.modify_active_directory_groups.getDisplayValue().toString().replace("\n",";");
e = current.variables.active_directory_groups_UAT.getDisplayValue().toString().replace("\n",";");
f = current.variables.active_directory_groups_newordelete.getDisplayValue().toString().replace("\n",";");
g = current.variables.modify_active_directory_groups_dailydropdown.getDisplayValue().toString().replace("\n",";");
current.variables.ad_groups=a+b+c+d+e+f+g;
Let me know if you have any further queries.
Please mark this as Correct or Helpful if it helps.
Thanks and Regards,
Abhijit
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
Hi Abhijit, getting error and also undefined
Hi Anusha,
Can you confirm all the 7 variables are multi line text type?
And I hope you are setting all values in AD groups variable(so you are not taking the values from that variable?)
and the above code is for which variable?
Murthy
