How to set the Due date of RITM and Task same as variable selected in Service Catalog
Naresh_5120
Hi Community,
I have created a termination form in Service Catalog item , when a termination form is filled by users, there is filed called Effective date (variable is name effective_date) select for the actual termination date. I want to show the same date as RITM Due date and Task due date, however it is not happening currently.
Can someone suggestion how can I achieve the output.
Effective Date Selected is -
RITM Date is showing is
Task Due date is showing is
 @Ankur Bawiskar I saw your other post where you have provided solution but that thread is closed, therefore tagging here for help!
11 REPLIES 11
Hi Ankur,
It is setting 1 day before the actual effective date
Hi Ankur,
with this script i am able to populate date only on RITM Due date not in Catalog task Due date.
current.setValue('due_date', new GlideDateTime(current.variables.effective_date) + ' 23:59:59');
