03-07-2022 12:25 AM
Hi
var gp = new GlideRecord('problem');
gp.addQuery('sys_id', current.sys_id);
gp.query();
while (gp.next()) {
gr.addQuery('problem_id', gp.sys_id);
while (gr.next()) {
gr.setValue('u_cause_code', '14');
gr.setValue('description', 'set from problem BR');
gr.setValue('work_notes','Incident closed by'+ gp.number);
gr.update();
})(current, previous);
I am trying set the work_notes in a similar way but it is not working.
I want to set my worknotes as "Incident closed by PRBxxxxx";
How can we set Incident worknotes in the above code?
Gayathri
03-07-2022 12:39 AM
update as this which is optimized
gr.addQuery('problem_id', current.getUniqueValue());
while (gr.next()) {
gr.work_notes = 'Incident closed by' + current.number;
gr.update();
03-07-2022 12:28 AM
Try like below..
gr.work_notes = 'Incident closed by'+ gp.number;
03-07-2022 12:31 AM
If still not working...
then add the below line after while (gp.next()) {
var number = gp.number;
Next, after gr.setValue line add below line
gr.work_notes = 'Incident closed by'+number;
03-07-2022 12:39 AM
while (gr.next()) {
gr.update();
03-07-2022 01:18 AM
It is working.
current.sys_id and current.getUniqueValue() both will fetch sys_id na, we can use any right?
