How to show only users from respective group in reference field (sys_user) table
Santhosh23
Can anyone please explain me how to filter the users from only one group in reference fields reference to sys_user table.
Ankur Bawiskar
you need to use advanced reference qualifier on that user reference field
javascript: 'sys_idIN' + new GetGroupMembers().getUsers();
Script include
var GetGroupMembers = Class.create();
GetGroupMembers.prototype = {
	initialize: function() {
	getUsers: function(){
		var arr = [];
		var gr = new GlideRecord("sys_user_grmember");
		gr.addQuery("group.name", "ABC Group");
		while(gr.next()) {
			arr.push(gr.getValue('user'));
		return arr.toString();
	type: 'GetGroupMembers'
Can this same script include be used for referencing multiple groups instead of just one?? If so, how??
@Brandon R1 Yes we can use it for multiple group.
var groupIDs = ['sys_id1','sys_id2','sys_id3'];  // save comma separated list of groups sys_id
		var arr = [];
		gr.addQuery("group.sys_id","IN", groupIDs.toString());  // and small change to this line
		while(gr.next()) {
thanks, it worked
Hi Ankur,
I have same scenario like this but in my case i am using
Script Include, On change where if I select a group in a variable
the variable 'list member' will only display member based on what the value in the selected group.
i try to pass the value from onchange to script include like changing "ABC Group".
Any thoughts how to apply this in onchange
Tim3
Using this script include method now requires users in the portal to have a license to view the results.
See KB0720034
This changed in June 2021.
If you require users without a license to view the results, you will need to edit the ACL, or re write the query on the variable
