How to sort the Subcategory by name
akshaybhardwaj
Giga Guru
I want to sort the subcategory choice list by name ,i got there is a sequence field in the choice table but we are having 200 subcategory so is there any other way i can do this?
Thanks in Advance
Thanks & Regards,
Akshay
jyothikalaadurt
Hi Akshay,
As per my experience, If u have dependent value, then remove sequence value and check, it will work. By default subcategories will come in alphabetical order.
I have tried its working fine.
Thanks Jyothi
For work around its fine like it takes sequence on its own but not everytime we can clear the sequence.
