how to to delete the process flow formatter ?
MoizM
Giga Contributor
Aditya_hublikar
Hello @MoizM ,
Refer this thread it will help you :
https://www.servicenow.com/community/servicenow-studio-forum/how-to-delete-process-flow-formatter-pe...
If this helps you then mark it as helpful and accept as solution.
Aditya
Hi Mr Aditya,
Thanks a lots for you help.
Thanks and Regards,
Mohammed  Moiz
Welcome ðŸ˜Š @MoizM .
SohamTipnis
Hi @MoizM,
You can simply make the processor inactive without needing it to be deleted.
Best practice would be to make it inactive rather than deleting it.
If you find my answer useful, please mark it as helpful and correct. â€Œâ€ŒðŸ˜Š
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
Dr Atul - LNG
@MoizM
Keep learning mate.!!
