How to trigger a notification when due date is approaching? using flow designer
Sathwik1
In a table I had a field "Due Date" now suppose
              -> When due is approaching in 30 days I need to trigger a notification...
              -> and when due date is approaching in 15 days again need to trigger a notification..
Is it possible by using flow designer? if so can anyone help me please...I am not getting how to set the condition to calculate 30 and 15 days using flow designer...
Hi Sathwik,
Hope you are safe and good.
You can try this with scheduled jobs.
  1. Create an event in the registry.
  2. Create a Scheduled script execution which runs daily at 0800 hrs.
        var chg_req=new GlideRecord('change_request');
               chg_req.addEncodedQuery('active=true^due_dateRELATIVEGT@dayofweek@ahead@29^due_dateRELATIVELT@dayofweek@ahead@31^NQdue_dateRELATIVEGT@dayofweek@ahead@14^due_dateRELATIVELT@dayofweek@ahead@16');
     chg_req.query();
       if(chg_req.hasNext())
          while(chg_req.next())
              gs.eventQueue('change_request.schedule_reminder',gr,gr.assigned_to.email,'');
    3. Create notification which sends the notification when the event got triggered.
In this example I have used Change Request table. Replace the table name in the glide record also due_date field name.
Please click on helpful if it is.
Thanks & Regards,
Sharath Allam
Kaptius - ServiceNow Premier Partner.
17 REPLIES 17
So sorry brother...didn't checked the month...
Thank you so much @Sharath Allam
Sathwik1
@Ankur Bawiskar @Prasad Pagar
Ankur Bawiskar
@Sathwik
You can easily achieve this with no script using flow designer.
Refer below link for the solution and enhance as per your use-case
how to send email notifications prior or 3 days befor valid date automatically
