How to trigger Email from flow designer after a particular time
GBS
I have created a flow and I want to send an e-mail to the requestor after 2 hours of task closure.
Any suggestions on where to set the time in Flow Designer.
9 REPLIES 9
You need to put data pill closed time relative Operators and use after 2 hr
@Dr Atul - LNG But, If I use the pill where I have to give the condition "State is Closed Complete"
Yes mate, you can add 2 conditions.
@Dr Atul - LNG can you please tell me what action to be selected if multiple records were found and also do I have to check the Don't fail on error check box?
Hi @GBS
