How to update short description and Description in REQ using inbound emails
Renu9
I am triggering a catalog item using an inbound email action where in a request gets created. But I see request short description and description fields are empty.
Inbound email is on sc_cart table. I am writing short description and description values in RITM and also in SCTask using the workflow which is on RITM table. Please guide me how to achieve of a short description and description values in REQ record.
var cartId = GlideGuid.generate(null);
    var cart = new Cart(cartId);
    var item = cart.addItem('a9503cff875e059025d00fe60cbb3584'); // Catalog item sys_id
                 cart.setVariable(item, 'employee_no', email.body.employee_number.toString());
                 cart.setVariable(item, 'employee_name', email.body.employee_name.toString());
                 cart.setVariable(item, 'country', email.body.country.toString());
       var rc = cart.placeOrder();
Hi, can you show me what you did as I ahve the same issue and not finding any solution in community or docs.....?  Thanks
Jaspal Singh
Mega Patron
Considering
will give your RITM no. can you try adding below
var ritmis=new GlideRecord('sc_req_item');
ritmis.addQuery('sys_id',rc.sys_id);
ritmis.query();
if(ritmis.next())
var reqis=new GlideRecord('sc_request');
reqis.addQuery('sys_id',ritmis.request);
reqis.query();
if(reqis.next())
reqis.short_description='ABC text here';
reqis.description='ABC text here';
reqis.update();
