How to visible and mandatory field once clicked on Button
Santoshi5
Giga Guru
Hi Developers,
I want to  make visible and mandatory ,explanation field once clicked on Reject button when we fill the details state changes to complete and record should be save.
Below is the UI Action &client script
client sacript:Onload()
function onLoad() {
g_form.setVisible('u_explanation',false);
Ui Action :
when i clicked on button field is visible and throwing error message but not changing state as nothing is happened ..
Great!  It looks like you marked your own response as the correct answer, which may be confusing to others that read this later.
I felt I covered that above pretty well (first) and included the script which pointed you in right direction on combination of client+server side code
If my answer solved your issue, please mark my answer as ✅ Correct & 👍Helpful based on the Impact.
please share updated code
please share updated script
I tried different script its working now, hope this will help to others,
Ui Action script _
function rejectAnalysis(){
if (g_form.getValue('u_explanation') == '') {
// Remove any existing field message, set comments mandatory, and show a new field message
try {
g_form.hideFieldMsg('u_explanation');
} catch(e) {}
g_form.setMandatory('u_explanation', true);
g_form.showFieldMsg('u_explanation', getMessage('Please provide the explanation '), 'error');
g_form.addErrorMessage('Please enter comments in the Explnanation ');
return false; // Abort submission
// Call the UI Action and skip the 'onclick' function
gsftSubmit(null, g_form.getFormElement(), 'reject_quality'); // MUST call the 'Action name' set in this UI Action
// Ensure call to server side function with no browser errors
if (typeof window == 'undefined')
serverReopen();
function serverReopen() {
// Set Incident state to active, update and reload the record
current.u_quality_state = 4;
current.update();
gs.addInfoMessage(gs.getMessage("Quality Analysis Submitted."));
