how to write a script for only alphabet letters using ServiceNow
Ashok M
The employee name should contain only alphabets and space and not more than 30 characters on the whole.
Raghu Ram Y
@Ashok M
1. Field should accept only string.
Create onChange Client Script on that particular field.
    var field = g_form.getValue('fieldname');
    if (!field.match(/^[A-Za-z ]*$/)) {
        alert('Please enter only text');
        g_form.clearValue('fieldname');
        return false;
2. Limit length to 30 Characters.
Right Click on the field and click on Configure Dictionary and set max length to 30 like below screenshot.
@Ashok M have you checked my suggestion? I hope it helps, if so please mark my response as correct and helpful.
Ashok M
Thanks Raghu
Hi, Can you please mark my response as HELPFUL and CORRECT, if it helps you
