how to write if condition for greater number in client script
Servicenow_12
Hi team,
I want to set assignment group using onload client script , if the number of users field value is greater than 200.
tried with below but its not entering into the loop.
var nou = g_form.getValue('number_of_users');
if (nou > 200) {
g_form.setValue("assignment_group", 'xyz');
Please help me with the right way of comparing the value with 200
PavanK960672992
Mega Patron
Hi @Servicenow_12 ,
Try below script on onload client script and active is true
function onLoad() {
  var num = parseInt(nou );
    if (num> 200) {
        g_form.setValue("assignment_group", '02826bf03710200044e0bfc8bcbe5d3f'); //add group sysid here
 If still not resolved try to add info message and check the value on number_of_users field.
or use display business rule and check and set it using onload client script
g_scratchpad.num=current.total_user;
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
11 REPLIES 11
nou = Number(nou)  or nou = parseInt(nou) can be used to convert the data type of number_of_users to Number from String.
'number_of_users' actually returns the value in number , not in string form.
using Number(nou) , i am getting the o/p as NaN
PavanK960672992
Mega Patron
Hi @Servicenow_12 ,
function onLoad() {
    if (num> 200) {
Pavankumar
Hi @PavanK960672992 ,
nou is 4565 (field value)
num is 4  (seems parseint returned number of digits)
Hi @Servicenow_12 ,
No that is not correct value. ParseInt parses the string and returns the whole number.
Pavankumar
