02-01-2025 12:17 AM
i am trying to create a consumable asset in the alm_consumable asset table but it is not populating correctly . as on the catalog item form , i have set a drop down list for the stock room and the catalog as reference .
Walk-Up Experience
02-02-2025 12:25 AM
@Ankur Bawiskar i found my answer which i was going in the wrong direction
i used this table with reference and it worked : cmdb_consumable_product_model
02-01-2025 01:32 AM
stockroom is a reference field to alm_stockroom table
Is your variable also referring to same table?
If yes then it will work, If not then it won't work
02-01-2025 02:24 AM - edited 02-01-2025 02:41 AM
02-01-2025 03:25 AM
@Ankur Bawiskar i tried to retrieve the variable as it is from a drop down list :
02-01-2025 04:22 AM
set the Lookup value field = SysId
Then try
