I am using OOB data certification. While certifying CIs , user should not be able to certify empty elements. Please see image in the description.
Sachin Gavhane
As shown in above pic, user should not be able to certify empty elements as marked in yellow. There should be some error when user tries to certify these empty elements.
Please help
Business Rule which you need to set up will look like below:
BR Details;
Table: Certification Element:
Condition: State Changes to Certified
Script :
	// Add your code here
	if(current.certified_value == ''){
		gs.addErrorMessage('Empty Field Values cannot be certified');
		current.setAbortAction(true);
})(current, previous);
Shloke
Shloke
16 REPLIES 16
You can add a filter for an empty string. just change to the correct field.
but am not sure which table should be used to restrict data certification
When user certifies their cert task, record for that cert task is updated in cert_element table with state of certified.
You need to configure business rules on cert_element table to abort transaction for any non filled values and check if state is being updated to "certified" with no value in "Certified value" field.
Shloke
Shloke
Also @Sachin Gavhane
I see you have created duplicate thread in community for the same purpose, please request to delete one of them and continue on one thread only.
Shloke
Shloke
BR Details;
Script :
Shloke
Shloke
