‎01-16-2022 04:26 AM
I have a already created and working PUT method in Scripted REST API. I need to edit this API to get one additional field value. Can someone provide similar references to anything that they know? I guess I just need to put a small code in the already existing code : Gliderecord the table, pass sys id of the ticket and extract the field value?
‎01-16-2022 08:11 AM
You need to update your code in two places:
1) You need to add below Line as shown after the line highlighted in Red below:
var automationResponse = requestString.AttributeName.toString(); // Replace "AttributeName" with the name of the Attribute 3rd party is sending in the payload.
Now you need to Update the field which you have created as Success or Error in Task table as shown below:
gr.FIELD_NAME_TO_Update = automationResponse; // Replace "FIELD_NAME_TO_Update" with the field name which you want to Update.
Also I have shared the complete code as well, where you just need to replace the highlighted areas as mentioned above:
var FulfilmentAutomationUpdateInterface = Class.create();
var util = new FulfilmentAutomationUtil();
FulfilmentAutomationUpdateInterface.prototype = {
initialize: function(response, sid, type, header) {
var config = util.coreConfig(sid, type, header); // check for core configurations
this.configFields = config;
if (JSUtil.doesNotHave(config.error)) {
if (type == "update") {
if (config.u_update) {
this.updateTicket = true;
return util.processError(response, 400, "Service account '" + gs.getUserDisplayName() + "' is not enabled for update operation.", "Update :" + config.u_update);
} else if (JSUtil.has(config.error)) {
return util.processError(response, 400, config.error, config.auth);
getResponse: function(request, response) {
if (this.updateTicket == true) {
var coreConfig = this.configFields;
var resDetails = {};
var integration_user_sys_id = gs.getUserID();
// Get the sys id of supplier of the integration user
var faObj = new FulfilmentAutomationUtil();
var integration_user_supplier = faObj.getIntegrationUserSupplier(integration_user_sys_id);
//GET ALL THE REQUEST PARAMETERS
var queryParameters = request.queryParams;
var taskID = request.pathParams.taskNumber;
var requestBody = request.body;
var requestString = requestBody.nextEntry();
var vState = faObj.getStates(requestString.state.toString());
var vSubState = faObj.getSubStates(requestString.substate.toString());
var vWorknotes = requestString.work_notes.toString();
var vClosure_notes = requestString.closure_notes.toString();
var vComments = requestString.additional_comments.toString();
var correlationID = requestString.correlation_id.toString();
var vAssigned_to = requestString.assigned_to.toString();
//var vAssignment_group = requestString.assignment_group.toString();
var attach_file_name = requestString.attach_file_name.toString();
var attach_file_type = requestString.attach_file_type.toString();
var attachment_base64 = requestString.attachment_base64.toString();
if ((!taskID)) {
//return new sn_ws_err.BadRequestError('Please provide a Task Number.');
util.processError(response, 400, "Please provide a Task Number.", "Please provide a Task Number.");
if (!vState && !vSubState && !vWorknotes && !vClosure_notes && !vComments && !correlationID && !vAssigned_to && !attach_file_name && !attach_file_type && !attachment_base64) {
//return new sn_ws_err.BadRequestError('The requested field cant be updated');
util.processError(response, 400, "The requested field can't be updated", "The requested field can't be updated");
//1 = OPEN, -6 = QUEUED
if (vState == 1 || vState == -6) {
//return new sn_ws_err.BadRequestError('Update not allowed for state value (' + vState + ') supplied ' + requestString.state.toString());
util.processError(response, 400, "Update not allowed.", "Update not allowed for state value '" + vState + "' supplied " + requestString.state.toString());
if((!vState) ){
return new sn_ws_err.BadRequestError('Please provide a state value.');
//2 = WORK IN PROGRESS
if((!vSubState && vState != 2) ){
return new sn_ws_err.BadRequestError('Please provide a sub-state value.');
if (vState.toString() == 'error') {
util.processError(response, 400, "Invalid state.", "Requested state in not valid '" + requestString.state.toString() + "'");
if (vSubState.toString() == 'error') {
util.processError(response, 400, "Invalid substate.", "Requested substate in not valid '" + requestString.substate.toString() + "'");
if (!vSubState && (vState == -5 || vState == 11)) {
//return new sn_ws_err.BadRequestError('Please provide a sub-state value.');
util.processError(response, 400, "Please provide a sub-state value.", "Please provide a sub-state value.");
//3 = CLOSED COMPLETE
//if ((!vClosure_notes && vState == 3)) {
if (JSUtil.nil(vClosure_notes.trim()) && vState == 3) {
//return new sn_ws_err.BadRequestError('Please provide a closure notes if state is closed_complete.');
util.processError(response, 400, "Please provide a closure notes if state is closed_complete.", "Please provide a closure notes if state is closed_complete.");
//Glide the table on which you want to post the record.
var gr = new GlideRecord('sc_task');
gr.addQuery('number', taskID);
//gr.addQuery('assignment_group.u_supplier',integration_user_supplier);
gr.addQuery('request_item.cat_item', 'IN', coreConfig.u_catalog_item);
gr.addQuery('assignment_group', 'IN', coreConfig.u_support_group);
//gr.addActiveQuery();
gr.setLimit(1);
if (gr.next()) {
if (vState && vSubState) {
if ((vState == 11) && (vSubState != 11 && vSubState != 5 && vSubState != 6 && vSubState != 20 && vSubState != 21 && vSubState != 22 && vSubState != 23 && vSubState != 24 && vSubState != 25 && vSubState != 26 && vSubState != 27 && vSubState != 28)) {
util.processError(response, 400, "Invalid state and substate combination", "Invalid state and substate combination");
if ((vState == -5) && (vSubState != 16 && vSubState != 14 && vSubState != 8 && vSubState != 12 && vSubState != 13 && vSubState != 9 && vSubState != 10 && vSubState != 15)) {
if ((vState == 3) && (vSubState != 29)) {
if ((vState == 7) && (vSubState)) {
if ((vState == 2) && (vSubState)) {
if ((vState == 4) && (vSubState)) {
if ((vState == 1) && (vSubState)) {
if ((vState == -6) && (vSubState)) {
if (!vState && vSubState) {
if ((gr.state == 11) && (vSubState != 11 && vSubState != 5 && vSubState != 6 && vSubState != 20 && vSubState != 21 && vSubState != 22 && vSubState != 23 && vSubState != 24 && vSubState != 25 && vSubState != 26 && vSubState != 27 && vSubState != 28)) {
if ((gr.state == -5) && (vSubState != 16 && vSubState != 14 && vSubState != 8 && vSubState != 12 && vSubState != 13 && vSubState != 9 && vSubState != 10 && vSubState != 15)) {
if ((gr.state == 3) && (vSubState != 29)) {
if ((gr.state == 7) && (vSubState)) {
if ((gr.state == 2) && (vSubState)) {
if ((gr.state == 4) && (vSubState)) {
if ((gr.state == 1) && (vSubState)) {
if ((gr.state == -6) && (vSubState)) {
if (vState != -6) {
//2 = WORK IN PROGRESS, 1 = OPEN, -5 = PENDING, 11 = AWAITING INFO
if (vState == 2 && (gr.state != 1 && gr.state != 2 && gr.state != -5 && gr.state != 11)) {
//3 = CLOSED COMPLETE, 4 = CLOSED IN COMPLETE, 7 = CLOSED CANCELLED, 2 = WORK IN PROGRESS
if ((vState == 3 || vState == 4 || vState == 7) && (gr.state != 2)) {
//-5 = PENDING, 1 = OPEN, 2 = WORK IN PROGRESS, 3 = CLOSED COMPLETE
if (vState == -5 && (gr.state != 1 && gr.state != 2 && gr.state != 3)) {
//11 = AWAITING INFO, 2 = WORK IN PROGRESS, 1 = OPEN
if (vState == 11 && (gr.state != 2 && gr.state != 1)) {
if((gr.state != 2) ){
if (vSubState) { //Only update if sub state is provided
gr.u_sub_state = vSubState;
if (vState == 2) { //If state is WORK_IN_PROGRESS, update substate to empty
gr.u_sub_state = '';
gr.work_notes = vWorknotes;
if ((vState)) { //Only update if state is provided
gr.state = vState;
// adding assignment group and assigned to
if (vAssigned_to) {
gr.assigned_to = this.getAssigned_to(vAssigned_to);
// if (vAssignment_group) {
// gr.assignment_group = this.getAssignment_group(vAssignment_group);
gr.u_closure_notes = vClosure_notes;
gr.correlation_id = correlationID;
gr.comments = vComments;
gr.update();
if (vState == -6) {
gr.update();
var fulfilmentAttach = new FulfilmentAutomationAttachUtil();
//This change is because, this particular line is calling the 'addAttachment' function in the 'FulfilmentAutomationAttachUtil' script include.
//As per the commented code , parameters such as 'tableName' and 'response' were missed, hence the attachments were not created. Hence the 'tableName' parameter is passed as null('') because the tableName will be set to sc_task when it is passed as empty.
//Refer 'addAttachment' function in the 'FulfilmentAutomationAttachUtil' script include.
//var result = fulfilmentAttach.addAttachment(taskID, attach_file_name, attach_file_type, attachment_base64);
var result = fulfilmentAttach.addAttachment(taskID, '', attach_file_name, attach_file_type, attachment_base64, response);
resDetails = {
"number": gr.number.getDisplayValue(),
"state": gr.state.getDisplayValue(),
"sys_updated_by": gr.sys_updated_by.getDisplayValue(),
"priority": gr.priority.getDisplayValue()
//"Message": taskID + " is updated successfully."
// resDetails = {
// "Message": taskID + " is not found or not active task.",
util.processError(response, 404, "Task number provided in request is not found or not active task.", taskID);
response.setContentType('application/json');
response.setStatus(200);
response.setBody(resDetails);
var writer = response.getStreamWriter();
return writer.writeString(JSON.stringify(resDetails));
getAssigned_to: function(assigned_to) {
var gr = new GlideRecord("sys_user");
gr.addQuery("user_name", assigned_to).addOrCondition("email", assigned_to);
gr.addActiveQuery(); // filter out inactive users
gr.setLimit(1);
if (gr.next()) {
//return gr.sys_id;
return gr.getValue('sys_id');
// getAssignment_group: function(assignment_group) {
// var gr = new GlideRecord("sys_user_group");
// gr.addQuery("name", assignment_group);
// gr.addActiveQuery(); // filter out inactive users
// gr.setLimit(1);
// gr.query();
// if (gr.next()) {
// //return gr.sys_id;
// return gr.getValue('sys_id');
type: 'FulfilmentAutomationUpdateInterface'
Shloke
Shloke
‎01-16-2022 09:24 AM
Hey Ekta,
Have you by mistake marked the incorrect response as correct? Please review, I have given the correct response with exact code which you need to use here in this scenario.
Shloke
Shloke
‎01-16-2022 09:44 AM
My bad! Just updated the correct response. Thank you, so much for helping Shloke.
