I need to set value in reference variable based on other reference variable.
varma2
Below is the client script in log i can see the value but it's not set in reference varible.
if(isLoading || g_form.getValue('device_name')!= '')
var mn = g_form.getReference('device_name', callback);
function callback(mn) {
g_form.setValue('device_serial', mn.serial_number);
    alert('Value='+ mn.serial_number);
Please suggest.
Thanks all.
Martin Ivanov
Hi. If my answer has helped you resolve your issue, Please mark Correct and Helpful. This way, other users may also benefit from the thread. Thanks!
Martin Ivanov
Community Rising Star 2022
Please mark Correct and click the Thumb up if my answer helps you resolve your issue. Thanks!
Martin Ivanov
ServiceNow MVP 2023, 2024
