i want to populate data without using Reference Qualifier.
Pruthviraj56
On incident form caller reference field, I want to display only HR department users but without using reference qualifier. Please help me with the what are the ways we can do this requirement ?
glideFather
I am not aware of any other option than that - reference qualifier basically makes "qualification" for the reference, why don't you want to use it, is there any motivation behind it?
Bhimashankar H
Hey,
You can try using matcher setter method, that way you can auto populate data from server side if any condition matches.
Bhimashankar
Chaitanya ILCR
Giga Patron
Hi @Pruthviraj56 ,
you can create a Query BR on sys_user table
with script
in the script replace the sysid with your hr departments sysid
    if (gs.action.getGlideURI().get('sysparm_target') == 'incident.caller_id')
        current.addQuery('department', '93b25282c0a8000b0b55c8ab34e2f1e6' /*replace this with your HR deparments sysid*/ );
})(current, previous);
Ref qual is the way to go but since you wanted a different way here it is
Chaitanya
