if condition for a list collector field in workflow
Atchutaram
Hi Everyone.
I have a requirement where there is a field called "services", and the type of field is list collector, i have given services table in that variable. there are two option: 1) mailbox 2) event queue. we have workflow, in which i used this list collector in "IF" block. this if should generate yes if "mailbox" is selected, it should also generate yes, if both the options are selected. How can i write a code for this.
var select = current.u_services.toString();
var selectArray = select.split(',');
var opt1 = selectArray.indexOf('3460adbfdb7e1b00dd1662eb0b96198a') !== -1;
var opt2 = selectArray.indexOf('3860adbfdb7e1b00dd1662eb0b96198b') !== -1;
if (opt1) {
    answer = true;
    answer = false;
I have given sys id of those two options.
Ankur Bawiskar
@Atchutaram
if you are using IF activity then it has a syntax and the answer variable should be set with yes/no
update your script as this
answer = ifScript();
function ifScript() {
    var select = current.variables.u_services.toString();
    if (opt1) {
        return 'yes';
        return 'no';
nemamuskan
Hello @Atchutaram
Please find the below script which I tried and tested for the requirement and it works for me.
Copy the Script as it is and it would work!!
    var opt1 = (selectArray.indexOf('3460adbfdb7e1b00dd1662eb0b96198a') !== -1); //mailbox
var opt2 = (selectArray.indexOf('3860adbfdb7e1b00dd1662eb0b96198b') !== -1); //event queue
        if (opt1||(opt1 && opt2)) {
                return 'yes';
                return 'no';
Thanks and Regards,
Muskan Nema
Hello @Atchutaram,
Greetings of the day!!
Just wanted to check if my reply answer was helpful to you and answers your question?
If my response helped, please mark it helpful and close the thread so that it benefits future readers.
Thanks, and Regards,
Muskan Nema
Mohammad Danis3
@Atchutaram ,
I hope you are doing well!
Did my response help you?
Please let me know if you stuck somewhere.
Mohammad Danish
