‎01-20-2022 09:15 AM
I have clearly mentioned the 'problem type' to be Root Cause Analysis but it takes General. Kindly help.
Suman P.
Change Management
‎01-26-2022 10:05 AM
I heard back on the Case I opened with ServiceNow. Never even noticed it but on your record insert test step just uncheck Enforce Security.
‎01-20-2022 09:39 AM
You have to mention PTASk type "root cause" in the Record Insert field. Can you please mention PTASK field value type?
akundu
‎01-20-2022 09:41 AM
Hi Abira,
if you see step 3 i have used Root Cause Analysis.
Suman P.
‎01-20-2022 09:50 AM
Hello Suman,
Can you please mention PTASK field value type? Once You can use "Set Field Values" step instead of "Record insert" for testing and check Type field value "Root cause "is set or not.
akundu
‎01-20-2022 09:57 AM
There is nothing like PTASK field value type.
Suman P.
