In ATF, for problem task it is always taking General
ServiceNow Use6
I have clearly mentioned the 'problem type' to be Root Cause Analysis but it takes General. Kindly help.
Suman P.
Brian Lancaster
Tera Sage
I heard back on the Case I opened with ServiceNow. Never even noticed it but on your record insert test step just uncheck Enforce Security.
25 REPLIES 25
ServiceNow Use6
Hi @Brian Lancaster ,
Any help please.
Suman P.
When you do your record insert of the task make sure the type is root cause analysis.
if you look at my test steps, step 3 says the same.
Suman P.
Let me check my test and see what it is doing.
Just setting type works for me. Here is a screenshot from when my test is running.
