‎01-20-2022 09:15 AM
I have clearly mentioned the 'problem type' to be Root Cause Analysis but it takes General. Kindly help.
Suman P.
Change Management
‎01-26-2022 10:05 AM
I heard back on the Case I opened with ServiceNow. Never even noticed it but on your record insert test step just uncheck Enforce Security.
‎01-20-2022 10:26 AM
I am doing exactly the same, i have no idea.
Suman P.
‎01-20-2022 10:31 AM
On things I noticed is on your record insert your are not setting the problem filed to the ID in step 2. Not sure if it will cause this issue but your problem task will not be associated to the problem. Screenshot from my test 3.
‎01-20-2022 10:37 AM
I did that Brian, it didn't make any difference.
Suman P.
‎01-20-2022 11:01 AM
I wonder if this is an issue with Rome. I'm still on Paris but I just did a test in my PDI and I'm getting the same results as you.
‎01-20-2022 11:05 AM
There is a difference on Problem Task between Paris and Rome. The ACL I mentioned in my other reply 🙂 That ACL is not on an out-of-the-box Paris instance.
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
