‎01-20-2022 09:15 AM
I have clearly mentioned the 'problem type' to be Root Cause Analysis but it takes General. Kindly help.
Suman P.
Change Management
‎01-26-2022 10:05 AM
I heard back on the Case I opened with ServiceNow. Never even noticed it but on your record insert test step just uncheck Enforce Security.
‎01-20-2022 11:11 AM
Yes just was checking on that. In Paris that ACL is not there. I will have to remember to modify that as part of the upgrade.
‎01-20-2022 10:16 AM
Hi there,
Don't know immediately how to solve this, need to think about it 🙂
Though I think the reason why is:
- Type is read-only and the default value is general
Why is it working when doing this manually?
- Because of the interceptor used
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
‎01-20-2022 10:20 AM
Hi Mark,
When I do it manually, it works fine.
Suman P.
‎01-20-2022 10:25 AM
Also just checked, this ACL is in the way of the Test:
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
‎01-20-2022 11:17 AM
I wonder why they add this ACL. Since the dictionary default is read only the only way to modify it outside the interceptor would be with a script.
