In what order does SN process a catalog client script when no order is defined.
Options
01-06-2023 01:57 PM
Example:
Client script 1 - has no order defined
Client script 2 - has order 100
Client script 3 - has order 200
Will the script1 get executed first, since it has no order defined? or will it get executed at the end?
Labels:
Service Catalog
Options
01-06-2023 05:21 PM
Hi @Job Easow2
I am sure the order that doesn't have will execute first, then CS will execute with the order 100, and then 200.
Hope it helps
