05-28-2020 02:44 AM
I have a requirement to show an alert if the record already exists in the table for the same name and show the link to the record through alert or infomessage. For this I wrote a Catalog client script and is working while doing 'Try it' but not working when I am trying the same through portal.
My OnChange Script:
var name = g_form.getValue('u_full_name');
var usr = new GlideRecord('u_eap');
usr.addQuery('u_full_name',name);
usr.query();
if(usr.next()){
var link = '<a href="u_eap.do?sys_id=' + usr.sys_id + '" class="breadcrumb" >' + usr.u_full_name + '</a>';
var message = 'The EAP record already exists for the name entered. Please check here' + link + ' .<br/>';
g_form.addInfoMessage(message);
Thanks in advance!
05-30-2020 08:40 AM
Hi Shwetha,
GlideRecord is not allowed in client script in portal; so it would break; Refer below
GlideRecord Client API does not work in the Service Catalog standard UI but works in Service Portal
You need to use GlideAjax + Script Include approach for this -> it would work in native and portal both
Updated code below for GlideAjax
Client Script:
var ga = new GlideAjax('u_userInfoAjax');
ga.addParam('sysparm_name', "getInfo");
ga.addParam('sysparm_userFullName', name);
ga.getXMLAnswer(callBackMethod);
function callBackMethod(response){
var answer = response;
if(answer != ''){
var link = '<a href="u_eap.do?sys_id=' + answer + '" class="breadcrumb" >' + g_form.getValue('u_full_name') + '</a>';
Script Include: Create Client Callable Script Include
var u_userInfoAjax = Class.create();
u_userInfoAjax.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getInfo: function(){
var name = this.getParameter('sysparm_userFullName');
usr.addQuery('u_full_name', name);
usr.query();
if(usr.next()){
return usr.sys_id;
return '';
type: 'u_userInfoAjax'
06-01-2020 05:01 PM
Today, i visited this YouTube video and in that they have mentioned the use of getMessage(). and it would really help if we are looking for language localization. But they have mentioned one thing is that g_form.addInfMessage(getMessage("MESSAGE_KEY")) is synchronous and won`t work in portal unless we make it a asynch.
Video Link here.20:56
Rahul
06-01-2020 11:31 PM
Hey Rahul,
Sure will let you know once I get a chance to check
