Insert and Insert and stay button
sandie
Kilo Expert
I am unable to view the Insert and Insert and Stay option on right click of the incident header. Please let me know how do we enable them
Pradeep Sharma
Hi Sandie,
go to sys_properties.list and then search for the property->glide.ui.task.insert
Make sure the value is set to true for this property.
Please let me know if you have any questions.
11 REPLIES 11
Hi Dan,
thanks for this.
Any reason why I was unable to see the option and mark it correct by myself
Dan Bruhn
Hi Sandy,
When you initially create a discussion there is a check box at the top that says "Mark this discussion as a question".   If you don't check that box it doesn't allow you to mark responses as "correct" or "helpful".
Hope this helps clarify.
Cheers,
Dan
Thanks Dan, it clarifies !!
Is this the same way to enable it under Maintain > Items when you are trying to add variables to a item or add values to a select box?   I only see insert and say if I right click at the top of the page.
Aman36
Kilo Explorer
I have done the mentioned steps and still unable to see insert and stay option in Hamburger menu
