08-04-2025 05:34 AM
Good evening.
Is there anyway, we can retrieve back the Flow context from RITMs, as it automatically gets deleted/expired after 10-15 days? Also, how should we change the validity period? Can we increase the expiration date? Is there any system property?
@Ankur Bawiskar @Dr Atul - LNG
08-04-2025 05:36 AM
08-04-2025 05:41 AM
Hi @AbdurRahmanSnow ,
You can still retrieve details about Flow executions mapped to a RITM using sys_flow_context, as long as the record hasn’t been automatically deleted yet. Once ServiceNow runs its cleanup or table rotation job on that Flow‑context, it is permanently removed with no undo...
08-04-2025 05:42 AM
This is done through the table cleaner, but be very carefully when you make adjustments. You should really ask yourself why you need to check on a flow that has run 2 weeks ago. If there were any issues, just recreate it and check what happens then.
FYI: the link shared by Atul will provide more info and also warnings on why you shouldn't make changes.
08-04-2025 05:43 AM
by default the flow context are retained for some days
check these links for more details
Save yourself from audit nightmare if you use Flow Designer
Flow execution details retention
08-04-2025 05:36 AM
08-04-2025 05:41 AM
08-04-2025 05:42 AM
08-04-2025 05:43 AM
