02-08-2022 02:56 AM
Hi All
My requirement is business will be encoding the attachment and sending that encoded value in excel format and the same we need to decode and transfer to ritm form via transform map.
So is it possible to do so? if yes how?. what transform script we need to use to achieve this functionality
Request Management
03-02-2022 06:34 AM
So you can use this in global scope
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
// Add your code here
var fileName = source.u_file_name;
var fileContentType = source.u_content_type; // such as image/jpeg or application/pdf
var fileData = source.u_base64_data;
var ecc = new GlideRecord('ecc_queue');
ecc.initialize();
ecc.agent = "AttachmentCreator";
ecc.topic = "AttachmentCreator";
ecc.name = fileName + ":" + fileContentType;
ecc.source = target.sys_class_name + ":" + target.sys_id;
ecc.payload = fileData;
ecc.insert();
})(source, map, log, target);
02-08-2022 04:19 AM
02-08-2022 04:29 AM
I hope you have given correct field names for the import set.
If yes then it should work fine and attach file with that file name to the target record
02-08-2022 04:44 AM
02-08-2022 06:29 AM
what does the excel contain?
Unless you have these details in the excel which I mentioned it won't work
1) the base64encoded data of the attachment
2) file name
3) content type
02-08-2022 09:10 PM
