is it possible to send attachment through transform map?
jobin1
Hi All
My requirement is business will be encoding the attachment and sending that encoded value in excel format and the same we need to decode and transfer to ritm form via transform map.
So is it possible to do so? if yes how?. what transform script we need to use to achieve this functionality
So you can use this in global scope
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
	// Add your code here
	var fileName = source.u_file_name;
	var fileContentType = source.u_content_type; // such as image/jpeg or application/pdf
	var fileData = source.u_base64_data;
	var ecc = new GlideRecord('ecc_queue');
	ecc.initialize();
	ecc.agent = "AttachmentCreator";
	ecc.topic = "AttachmentCreator";
	ecc.name = fileName + ":" + fileContentType;
	ecc.source = target.sys_class_name + ":" + target.sys_id;
	ecc.payload = fileData;
	ecc.insert();
})(source, map, log, target);
32 REPLIES 32
@Ankur Bawiskar It will work if I use below script(remove bae64) but again bae64 decording is not happening but it will attach in ritm.
so are you saying it's working only for text/csv file?
	var sa = new GlideSysAttachment();
	sa.write(target, fileName, fileContentType, fileData);
@Ankur Bawiskar No its not working for any of the types. Decoding is not happed till now. Only encoded file will attach if we remove sa.write/bae64 code line.
it worked for me; you can also try to test it from background script
gr.get('bffc56dd071c01102011ff208c1ed0b9');
var fileName = 'hello.txt';
var fileContentType = 'text/plain'; // such as image/jpeg or application/pdf
var fileData = 'dGhpcyBpcyBteSB0ZXh0IGZpbGU=';
ecc.initialize();
ecc.source = gr.sys_class_name + ":" + gr.sys_id;
ecc.insert();
File data in base64
Record output
	ecc.initialize();
	ecc.insert();
