Is there a class definition somewhere for GlideColumnAttributes
ericroberts
I am working with the background script below learning how to create  a table using script.  It is working great.
Re: the GlideColumnAttributes class or method, I only saw sample code that used the following:
columnAttributes.setType("string");
columnAttributes.setUsePrefix(false);
Is there a place where all the other options are documented that I can use?  The main one I need is character length.  But it'd be nice to know what else I can set if at all possible.
ER
// Create general table settings
var table_name = 'u_a_test_table_creation_by_background_script',
    extends_table = 'undefined';
//Set table attributes container
var tableAttributes = new Packages.java.util.HashMap();
//Add columns via function call
addColumn('ORG_CODE');
addColumn('L2_DESC');
addColumn('L3_DESC');
addColumn('STAFF_NBR');
addColumn('POSITION_NBR');
//Create table and push in all attributes both table and column
var tableCreator = new GlideTableCreator(table_name , table_name);
tableCreator.setColumnAttributes(tableAttributes);
if(typeof extends_table != 'undefined') tableCreator.setExtends(extends_table);
tableCreator.update();
function addColumn(columnName){
var columnAttributes = new GlideColumnAttributes(columnName);
tableAttributes.put(columnName, columnAttributes);
sergiu_panaite
Unfortunately it is not documented.
But for your particular case you can use:
columnAttributes.setLength('100');
If you don't set a length a default one will be set automatically (40 for string).
On the other hand you can run the following script to see what methods are available:
var ca = new GlideColumnAttributes('incident');
for (var member in ca)
gs.print(member);
Gives me:
[0:00:00.003] Script completed in scope global: script
*** Script: getClass
*** Script: wait
*** Script: getLabel
*** Script: getName
*** Script: usePrefix
*** Script: notifyAll
*** Script: values
*** Script: setUsePrefix
*** Script: getColumnName
*** Script: type
*** Script: getReferenceTable
*** Script: notify
*** Script: setPrefixSysFields
*** Script: hashCode
*** Script: setUseOptimizedNameCleaner
*** Script: class
*** Script: addValue
*** Script: referenceTable
*** Script: prefixSysFields
*** Script: getValues
*** Script: length
*** Script: useOptimizedNameCleaner
*** Script: label
*** Script: setType
*** Script: intLength
*** Script: setReferenceTable
*** Script: isUseOptimizedNameCleaner
*** Script: setLength
*** Script: getType
*** Script: equals
*** Script: name
*** Script: getLength
*** Script: getIntLength
*** Script: setLabel
*** Script: DBName
*** Script: toString
*** Script: getDBName
*** Script: columnName
Sergiu
ericroberts
Disregard my last post ... I got it ... seems that 40 chars for a string value at least using this method is the minimum I can put in ... if I put in anything less than 40 it defaults to 40 ... if I put in 41 ... or 100 .. I get the value I want.
I can go in manually after the fact and reduce the size of a text field to 4 chars if I wish...but not using this method it seems.
This is ok...as my main issue is wanting to increase the char value of text fields based on my import data.
ER
