Is there possibility to create catalog task after immediate approvals in ritm
aj2403
I have ritm to be created with 4 approvals. i configured the conditional script on the approval process. Suppose 1st user approved, immediately catalog task has to created and second user approved, immediately one more catalog task to be created. If others are rejected, as per conditional script that will go to another activity.
I am not looking from business rule but from workflow can we acheive or not. Kindly help me on this.
Aj
Thanks for the reply. I will explain better. Let me know if you got it or not.
I have a glide list variable referred to location where user can select upto 5 locations. each location will have 1 approver. If user selects 4 locations, then at a time 4 approvers has to attach for that ritm.
i configured the conditional based script on the approval activity. As per the functionality the approval activity will wait until all the approvers take the decision to approve or reject.
Suppose 1st user approved, immediately catalog task has to created and second user approved, immediately one more catalog task to be created. If others are rejected, as per conditional script that will go to another activity in the workflow
SLK Gupta
HI @aj2403 ,
You can use activities in workflow, you can use add catalog task one.(suggested by others as well)
After each approval you can give this catalog task for if approved only then it will create a catalog tasks after each approval -as per your requirement @aj2403 .
Mark my answer as accepted Solution or helpful if it assists you in anyway @aj2403 .
let me know if you need any further assistance.
 Thanks & regards,
S. Lakshmikanth Gupta.
