Issue Copying All Attachments from Task to RITM in Flow Designer
monica_detani
Hi Team,
I’m facing an issue where I am unable to copy all attachments from a task to the corresponding RITM using Flow Designer.
I have two inputs:
RITM (referencing the sc_req_item table)
SC_Task (referencing the sc_task table)
My approach:
I look up records in the sys_attachment table using a filter to find attachments related to the sc_task.
I use a For Each loop to iterate through the retrieved attachments.
Within the loop, I call the Copy Attachment action.
Issue:
Only one attachment is getting copied instead of all.
@monica_detani
I just tested and it worked fine for me
I am passing task sysId and RITM GlideRecord object as input to subflow
Check this
9 REPLIES 9
Hi @Ankur Bawiskar
As I mentioned in my question, the issue is that only one attachment is being copied instead of all.
@monica_detani
in your flow execution it shows Run time value for Source Attachment record as empty
If it's working for 1 record then it should work for 2nd as well.
@Ankur Bawiskar Thanks for your response, but that's exactly the issue, I am unable to reproduce it.
@monica_detani
Did you test it with different SC Task and RITMs?
Subflow is running as System user?
what's the input type for ritm? Is it reference to RITM table?
@monica_detani
Check this
