Issue with Add Users to Group in the flow designer
Admin7267
I have configured a flow using Add Users to Group and facing an error:
PowershellProcessRunner was interrupted to complete in 300 seconds
It is happening at instance level not specific to one particular flow and I need help to fix this.
abbasshaik4
Tera Sage
Hello @Admin7267,
Please refer to the link below:
In flow designer action, Powershell step fails with error "PowershellProcessRunner was interrupted t...
If it is helpful, please mark it as helpful and accept the correct solution by referring to this solution in the future it will be helpful to them.
Thanks & Regards,
Abbas Shaik
yashkamde
Hello @Admin7267 ,
This error states that your PowerShell step or probe exceeded the default 300-second (5-minute) timeout limit.
Try these steps :
1) Just try restarting the MID Server service! Sometimes the simplest solution might help.
2) Configuration Adjustments - Increase Timeout
Refer this : https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1383178
