ITSM Implementation Simulator
MNGT2022
I am stuck on task 13 ( Auto-assign a problem record)
Any problem record that is associated with the E-Commerce service should automatically be assigned to the IT Securities group.
1. Create a new assignment record named E-Commerce Problems that automatically assigns problem records to the IT Securities group when Service = E-Commerce.
Tip: Review existing Assignment Rule records related to the problem table for comparison
At the top of the options you will find the "problem fields". By selecting this option the filter will reset and you will be able to find the correct "Service" option.
JP Tagarda
Hello to solve this you will need to delete the default script in the ff. field
JP Tagarda
you will need to delete the default script here to solve this
satyac2
Navigate to All > System Policy > Assignment and click New.
Complete the form using the following information.
Applies To tab or section:
Table: Problem [problem]
Conditions: Service is {E-Commerce}.
Group in the Assign To tab or section: IT Securities
Click Submit.
Test the assignment rule by completing the following steps.
Navigate to Problem > Create New.
Complete the problem form and select a configuration item with a Service is E-Commerce.
Click Submit.
Open the problem and verify that the assignment group was added.
