ITSM Simulator - Insufficient Lead Time not Validated
Stefan Cojocaru
Hello all,
I'm doing the simulator for CIS - ITSM and i'm stuck with this task:
Change requests without sufficient lead time pose a greater risk to the environment and should be documented as such. Risk calculations should consider required lead times, as defined by the organization's change policy:
- If lead time of 7 days is not met for model = Normal change request, Risk should be set as "High", Impact should be left alone.
- If lead time of 3 days is not met for model = Standard change request, Risk should be set as "Moderate", Impact should be left alone.
1. Disable Risk Condition "Insufficient lead time".  (completed successfully)
-> to be solved: 2. Add a new risk condition: "Insufficient lead time - Normal Change" so that if a lead time of 7 days is not met for Normal change requests, the Risk will automatically be set to High, and Impact should be left alone.
-> to be solved: 3. Add a new risk condition: "Insufficient lead time - Standard Change" so that if a lead time of 3 days is not met for Standard change requests, the Risk will automatically be set to Moderate, and Impact should be left alone.
------- Screenshot with the way i'm implementing it is attached. Can you tell what is missing?
Thank you this was helpful!
I was also struggling, so these screenshots were more than helpful. I am only not sure why we need to choose Model instead of Type 🤔
ShamedC
This was very helpful! I was able to validate using three conditions:
  • Planned Start Date is not empty
  • Planned Start Date relative after 7 Days from now
  • Model is Normal
Just replace the duration and model type based on the actual risk condition you're creating
JohnnyJ
Giga Contributor
I think it was looking for Model <is><Normal>  instead of task<is><Normal?
madjidtaiat
I have attempted this, and it successfully validated my task 🙂  I am attaching the screenshots of my task. I hope this helps.
