JavaScript - calculate number values in a string
05-23-2019 12:43 PM
I am working on a script where I need a read an output and calculate the numbers at end of each line. I am trying the below script but I am unable make it further.
Note: script should be able to add values of 'Local Fixed disk' ONLY.
Output I get in the ecc queue:
Caption Description Size
C: Local Fixed Disk 64422408192
D: Local Fixed Disk 999645245440
G: CD-ROM Disc 99884729
Script to read and calculate the size
//I pasted the above output in the Incident short descripion to make script running easier.
gr.get('number','INC7914138');
var output= gr.description;
var lines = output.split('\n');
var diskSpace = 0;
for (var i = 0; i < lines.length; i++)
var newArray = lines[i];
if (newArray.indexOf('Local Fixed Disk'))
var n = newArray.split(" ");
var disk = (n[n.length - 1]);
diskSpace = diskSpace + parseInt(disk);
gs.print(diskSpace);
Expected output:
//addition
64422408192+999645245440 = 1064067653632
05-23-2019 01:35 PM
Paul,
The script below should do the trick:
var output = "Caption Description Size\n\nC: Local Fixed Disk 64422408192\n\nD: Local Fixed Disk 999645245440\n\nG: CD-ROM Disc 99884729";
var diskSpace = 0;
for(var i = 0; i < lines.length; i++) {
if (newArray.indexOf('Local Fixed Disk') > -1) {
console.log(diskSpace);
Derrick Johnson
05-23-2019 01:35 PM
//PUT the gs.print(diskSpace) out side of the for loop
//gs.info("newArray =" + i + " = " + newArray);
var disk = (n[n.length-1]);
