Knowledge Feedback Task is going to Default Assignee
sayan-ghosh
Hello Team,
Whenever I am submitting the Knowledge Feedback Task.
The Task is assigning to Particular Knowledge Group Default Assignee.
But the Requirement is The Assigned to needs to be Empty
Created Client Script:
Please Help me to achieve this.
Best Regards
17 REPLIES 17
Hello @sayan-ghosh
This is OOTB assignment rule for kb_feedback_task and it will be executed only if Feedback.Article  is not empty.
You can disable this assignment rule OR modify it, if it is not impacting anything else (ideally it wont).
Please test it once after disabling it and also do the impact analysis for the same.
Note - Please do it on non prod instance.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this question to solved bucket.
Prathamesh
sorry mate no idea, try to add your question in dedicated forum
https://www.servicenow.com/community/knowledge-managers/gh-p/knowledge-managers-
swapnali ombale
Hi @sayan-ghosh
In your client script use
g_form.clearValue('assigned_to');
Instead of using
g_form.setValue('assigned_to',' ') ;
No it is also not working
@sayan-ghosh exactly what you are expecting when group changes then assigned_to should empty or when task created that time assigned to should be empty?
